midwayfair
I just finished a pair of preamps (based on the Hamptone FET preamp but less gain) that has some low-frequency hum the my DAW reads as much as ~-48dB at full gain (~62dB), when loaded by an e609 dynamic, which I think is unacceptable and it's much more than other preamps I have around. If I move the preamp box away from my computer/interface or sit it onto its side (90 degree angle), the hum drops to -55 to -60dB and is only a little louder than hiss, which isn't perfect but is certainly very good. I tested for hum with the other pres I have (an ART MPAII, the pres in my Scarlett interface, and a Baby Animal Neutral pair I finished recently) and those are all closer to -70dB for the 60 cycle hum.
The input transformers are Edcor XSM, 600:10K. Here are the transformer docs: https://www.edcorusa.com/xsm600-10k
I did the following to verify that it was definitely being generated at the input transformer:
Other things:
[list type=decimal]
[*]The hum is less (not just better signal:noise) with any sort of active mic, but it's still there. It's around -60dB at worst with a small diaphram condenser with 150R termination (I'm using my DAW for the analysis). I really have no idea what that indicates.
[*]The box is a hammond aluminum 12x8x2 chassis. I've built guitar amps in these that are quiet, but those had shielded transformers. Everything is well grounded, and there aren't any symptoms of ground loops (i.e. no buzzing).
[*]There ARE harmonics from the hum at 120Hz and 180Hz, but they are minimal. I've already replaced filtering caps, but it's my understanding that if it were bad filter caps the hum would be most prominent at 120Hz, not 60.
[*]The transformers are open, so I wrapped one of the input transformers in foil and then grounded the shield to the chassis, but this does not change the hum at all. I'm not sure I could effectively shield a transformer anyway, because this means it's a magnetic field problem and the aluminum isn't a magnetic shield, right?
[/list]
May or may not be relevant:
Is there anything I can do about this? I've read more than once that the only thing that can really be done about radiating hum is to move the device away from whatever it's picking up interference from, but that's less than ideal.
I have nothing else with transformers and no other transformers to test with.
Do I have to just get something with a humbucking coil? I'm having a hard time finding those. Cinemag's CMMI-8C or CM-75101A both have the right ratios but I can't figure out if they're humbucking. None of the Jensen transformers seem to have a primary above 150R, which I don't really think is high enough.
- There is no hum using the DI, e.g. with a guitar (except from the guitar pickups with single coils) -- this bypasses the input transformer.
- When I turn the pad down, the hum gets quieter(I get more hiss, though, as expected). This does not change the signal:noise, however: I confirmed it confirmed by recording a sample with the -18dB pad in and out and then applying +18dB of gain. The hum is exactly the same level.
- If I ground the input connection to the PCB, there is no noise at all even with the gain at maximum, except a very very low level of hiss, so the hum must be created prior to the PCB input connection.
- Reducing the input capacitor filters out some of the hum.
- Turning down the gain decreases the amount of hum (but does not change the signal:noise).
- If I ground the center tap of the Input transformer. This, again, doesn't change the signal:noise ratio.
- The placement of the transformers inside the box itself doesn't matter except as it relates to anything radiating.
Other things:
[list type=decimal]
[/list]
- When I first wired it up I messed up and had the center taps grounded on the primary (derp), which put DC across the coil. I did not identify any damage -- no heat or smoke or anything like that -- and I corrected the mistake quickly.
