Hi there! I hope this time, someone can help me.
I'm having problems calibrating a pair of fc526-xfmr. My dad built them a couple of years ago and unfortunately, my father passed away from COVID and never calibrated them as I mentioned on my last post ( never get a reply...)
They were never used and now I'm trying to do calibrate.
First, I connected it and moved the Q-bias CW to leave it open, put a signal in the input (-30dBu 1khz sine wave = 24.50 mV) and it gave me 7.7 dBu (1.8800 volts). Everything seems correct. The test points seem correct:
TP1: 5.92 mV
TP2: 119.7 mV
TP3: 0.950 V
TP9: -10.01 V
2.508 V at top of the meter resistor (11)
Then, I increase my generator output (DAW) until it reaches 8dBu (1.9456 V), I start lowering the q-bias CCW and leave it at -7dBu (1.7341 volts) but I notice that after a while, this value slowly decreases.... I readjust it and continue with the LED calibration, everything seems correct, when activating the GR it drops 7 decibels (in the DAW I put it in an input of my interface and it gave -1.2 db and when triggering the GR switch it gives me -8.2) everything seems perfect.... TP7 almost matches what's written on the FET bag: TP7: -1.48
FET bag: -1.18
read in the fc526 build forum that you mention this should be between -1.4 and -1.7 so everything seems correct.
I decided to leave it connected with the signal and this is where the problem is with both - the voltage keeps dropping. I left it connected for 8 hours, thought it was a matter of stabilizing but no. I kept testing for 4 or 5 days leaving them connected for more than 11 hours, one with signal and one without signal but turned on. Two days ago I recalibrated it after leaving it on for 9 hours and I've taken measurements for two consecutive days and it's more or less the same always on all days (the output voltage drops more or less the same). This is what happens, on one side it shows the volts it's giving me at the fc526 output, injecting 1khz @ -35.6 db (this is what gave me 8dBu at the fc526 output when I calibrated it and set the q-bias to 7dbu, that is, at 1.7341 volts) and this is the result by hours of the day, two days after doing the second calibration:
Volts: Time:
1.8010 - 10:00 am
1.7535 - 12:00 pm
1.7483 - 12:30 pm
1.7464 - 1:00 pm
1.7440 - 2:00 pm
1.7400 - 2:30 pm
1.7380 - 3:00 pm
1.7365 - 4:00 pm
1.7342 - 7:00 pm
1.7371 - 8:00 pm
This is yesterday's result:
Volts Time:
1.7940 - 9:30 am
1.7610 - 10:00 am
1.7490 - 12:00 pm
1.7390 - 2:00 pm
1.7310 - 3:00 pm
1.7260 - 5:00 pm
1.7264 - 6:00 pm
1.7280 - 8:00 pm
1.7310 - 9:00pm
1.7350 - 11:00 pm
It's worth mentioning that the measurement moves slightly in small circles cycles, first slowly increasing and then slowly decreasing. I tried connecting the rack directly to power and also through a power conditioner, and the results are similar.
What I'm using is an empty capi rack 511 (only the two modules connected and tested in different slots) with original CAPI power supply, my beloved Unit-T 117c multimeter capable of measuring 1khz with 60,000 counts.
Is this behavior normal? If it's correct, when do I do the calibration? Because when I leave it fine after 8 hours of being on, it's perfect, but the next day when turning it on again, no LED lights up and the difference is quite large. Am I doing something wrong?
My measurements are sending the sound wave from the DAW, from there it goes out of my interface and I measure it by connecting pins 2 and 3 to my multimeter, then I connect it to the fc526, and from the fc526 output I measure with the multimeter again (in my two fc526s, when putting them in bypass, it's exactly the same volts as those from the interface output). And I always check the volts from the interface output before measuring the fc526 output volts to make sure I'm always injecting the same level.
I hope anyone can help me, I'm desperate already, it took me a long time to figure out how to do the calibration and even longer testing, kind regards.
