Sorry for the vague post...can not give too many specifics...
I have a solid state guitar amp with an issue and wondering if anyone can help me analyze this circuit. I am a little unsure of whats going on here., specifically the "bias" and "trigger" circuit.
I have good signal from the pre-amplifier section (no schematics attached) into the "driver circuit" and then signal drops feeding the power amplifier. The amplifier is rated at 300 watt into 4 ohm but really gets about 80 watts. As far as I can determine the amplifier and power devices are functioning. I think there is an issue in the dirver circuit. Signal up to sencond half of opamp U1-b is ok but then i loose it. Op amp is ok.
Bias is plus and minus 1 volt DC sine wave on speaker output jack shows on all connections: CT, B+, T+, T-, B-
See next post for power amp
