Samuel Groner
Hi
Having the latest non-working incarnation of one of my discrete opamps on the bench: [removed]
A few (probably irrelevant) corrections on the schemo:
* R1, R2, R9 = 91 ohm
* C1a open
* C1b = 100 pF in serie with 120 ohm
* C2 open
* Vsupply = +/- 15 V
The diff. input stage works OK, except that the right leg conducts a bit more than the left (voltage drop across R3 = 460 mV and across R4 = 530 mV). Across R7, I measure around 600 mV, the second CCS is saturated (@ 1.3 mA or so), D5-D7 do not conduct and the output stage is (obviously) dried out as well.
I replaced Q9, no change and the unsoldered transistors seems to be OK. Shorting Q9 emitter to collector makes things going and the second CCS as well as the the output stage run at a good quiescent current.
Any hints where to look next?
Samuel
* C1a open
* C2 open
Samuel
