Help with U87
chownmander
New member
UK
Original DIY-U87 build thread here - https://groupdiy.com/threads/neumann-vintage-u87-clone-build-thread.48030/
I need some guidance here. I've build the mic and tested it - works in my DAW.
However, the audio is steeped in a (quiet but noticeable) white-noise interference sound beneath the recording audio.
I plugged in another DIY-U87 into my DAW straight after, and it sounds crystal clear. No white noise.
So far, I've had assistance from someone who has previously built a few DIY U87.
- changed the transformer for a known working one.
- swapped transistor with a new one
- checked all leads from board-to-board, and capsule-to-board
- checked switch PCB connections
- general tidying of all solder connections
Not sure where to go from here. Any suggestions?
Many thanks
Many thanks
Did you clean the high impedance area with isopropyl alcohol? (capsule connections, attenuation pad switch , pattern switch pcb, jFET input circuit, etc.)
    168.1 KB
    304.6 KB
    138.7 KB
    311.6 KB
    174.2 KB
Also, if you could post a copy of the actual schematic & component values you used, that would help.
This is the BoM I used from Mouser - https://bit.ly/3WsYbj3
The obsolete items which are listed, I replaced with -
1
RoHS1660-GS1/4LC686J
GS1/4LC686J
KOA Speer Metal Film Resistors - Through Hole 1/4 WATT 68M OHM 5%
2
RoHS2594-2222-021-28109
MAL202128109E3
Vishay Aluminum Electrolytic Capacitors - Axial Leaded 10uF 63V 20% Axial
3
279-H4P560RFCA
H4P560RFCA
TE Connectivity Metal Film Resistors - Through Hole H4P 560R 1% 50PPM
4
RoHS172-T93YA-25K
T93YA253KT20
Vishay Trimmer Resistors - Through Hole 3/8" SQ V/ADJ 25K
I mainly followed the steps taken to build on this page, with it being same PCB and microphone - https://www.vintagemicrophonepcbkit.com/Neumann U87 Build.htm
Hope this helps?
The high amount of flux on the back of all three PCBs is not helping. I suggest you start by completely cleaning all of them, especially around the high impedance sections mentioned above, and then check if your problem still persists.
And as @Khron mentioned, that brown stuff is problematic too, looks like a lot of overheating went on during your build.
The photo shows that the FET gate is soldered directly to the board
The arrow indicates the place where the fluoroplastic turret should be located for soldering the gate
