Help with Yamaha PM-2000 Restoration and MOD
Pip
New York City
If you where going to add Direct channel outputs where and how would you do it? See link to schematic below.
- Would you tap off at the post input fader, pre pan circuit point?
- Would you use transformers or active circuitry?
- If you used transformers would you use 600-600 Ohm matching or some other value?
- If you used active would you use something like THAT Corp 1646 balanced line IC or something else?
http://pmtaudio.com/Yammy/PM2000-Schematics.pdf
