recently became the owner of a Hill Audio 16 channel mixer. Reviews of it are interesting and I want to start testing it out, using it as mic preamps pre converter.
The power supply to this unit has something wrong:
I tested 3 of the 4 fuses. 3 were bad, so I replace them. If I connect my multimeter in resistance mode connected to the fuses, 2 of them will individually light up either the psu power LED or the phantom power LED. When testing the other two fuses, no visual indication of yes or no. I re soldered a joint that looked obviously bad and now I'm stuck as what to test next. I've gone through most of the components and they all seem functional. There is however a orangeish tint over 1/4 of the back of the PCB. A few other forums indicate this could be solder residue but should wipe right off and not be the cause of this issue.
Any insight would be greatly appreciated
