I know that feeling. Life on the property dictates priorities. I have a friend who is a rep and did very well. He’s the one that told me about the popularity of the champ 12 with different players. I had a black face Princeton back around 1970. I learned a lot of guitar on that amp. It’s a classic. The SFPR of Louie’s caught my attention. If I had my BFPR I would never want to touch it inside. I’m just saying a chassis is an open slate so you don’t mess up something that is a classic for someone else.
BF and earlier are definitely restoration only AFIAC. I remember seeing a rig walk through of TPATH guitar rigs some years back. They had the big Vox Super Beatles on stage, but they were just props. Mike Campbell's main amp was a little BFPR tucked away back stage and miced up. I think he might have also had a tweed of some kind for a few tunes.
One of my Vibro Champs (both '77 models) is practically brand new. I will only touch electrolytics on that one. The other one was clearly used. Speaker was tired. I put a new 8" Alnico in it (Jensen, IIRC), recapped electros, rewired heaters with resistor "CT," and added an extra RC filter stage to B+ to drop voltage slightly and reduce hum. I might have tweaked the mid resistor, too. Nothing radical.
My SFDR, also a '77, was a tired player's amp that I got for $275 in 1991. Cabinet in good shape, Utah (?) speaker very tired. Someone had wired series strings of 1N4007 diodes across the 5U4 socket and B+ was something close to 500V.
Over time I undid the hacks, recapped it, mostly blackfaced it, then did the reverb & trem on both channels mod, then reworked the normal channel with a 12AY7 and less scooped midrange. I snipped the bright cap, too. Last thing was a vox cut control wired onto a plate covering the rear accessory outlet and repurposing of the death switch for a three position NFB control: BF (standard 820R), tweed (open--no NFB), and brownface (a few K--I did the calc to accomodate PI input differences, don't recall exact value).
I don't regret the changes. The amp is my favorite to play. NFB switch is a great mod. The amp can easily be restored to near BF spec in a couple of hours if desired.
