Lowfreq
Hi all,
I've always found my gssls to have a slight smearing in the high frequencies that bugged me, so after reading some posts by Kingston, I decided to whip out the bypass caps in the audio sections to see if it made any difference. I'm using Nichicon PW elecs and Wima polyprops.
Before I whipped em out I kept switching between an itb mix with and without the gssl inserted on the stereo bus. There was a definite difference that I could hear, and my wife picked it out in a blind test everytime.
But after removing the film caps, the difference between gssl inserted and not inserted was minimal at best. My wife couldn't pick which was which, and they sounded really close to my ears. (no compression used, just running signal through the unit)
So i'm confused...... I thought the polys were there to help the sound. To help in the "air" frequencies? After doing a lot of searching and reading, it seems to be something some people say helps, while others say it doesn't.
Also, if I'm using my gssl on an insert only, and there's no chance of 48v hitting it, can I get away with using a jumper instead of the 22uf and 100uf electrolytic caps (film caps are not an option.. too big). What is it protecting it from? And what about the 22uf between the input 5534 and the vca?
Or are these electrolytics not really hurting the sound at all? I kinda thought they were the caps to avoid in your audio path if possible.
Wow, it did!! The smearing of the sound is goneKingston said:GSSL input and output are filled with 100nF bypass caps for the electrolytics. They actually degrade audio signal quality, especially if you have even halfway decent electrolytics. They should be removed.
