PRR said:If you go 1000' south of my house into the woods, you may not need magnetic shielding on a mic transformer.
If you go 1000' north of my house into the woods, you WILL not need magnetic shielding, for the field from the transmission lines.
Almost any place you want to record (near power) you will need shielding. I have got-by with steel utility box for low-quality audio where a little hum was accepted, but not good audio.
Mu is not essential. 3 or 4 "russian doll" nesting steel boxes, not touching each other, may be as good as 1 or 2 layers of Mu.
Magnetic shields don't need to be grounded to work. I think PRR means held apart by non-ferric means (like plastic or brass standoffs).Newmarket said:Mmmm...when you say "not touching each other," - do you mean not touching but individually grounded or some / all 'floating' ...? Cheers.
ruffrecords said:Magnetic shields don't need to be grounded to work. I think PRR means held apart by non-ferric means (like plastic or brass standoffs).
rackmonkey said:So your copper worked well, Pucho? For EMI shielding, it's my understanding that magnetic permeability matters most in the shielding material. Copper is pretty low in that regard. I would think it would work well for RFI shielding, but less so for induced magnetic interference.
ruffrecords said:For mic transformers, mu metal shielding is essential.
But... transformers are bandpass filters that generally scrub off excessive RF energy making rectification in later active gain stages less likely.rmburrow said:Agree 100 per cent...but RF is sneaky...depending on the intensity, audio rectification can occur in the gain stages with resulting degradation...
Copper will do nothing to stop EMF interference. It is used to combat RF, a whole different animal. You could easily prove this using one of the copper shielding kits for guitar cavities. Mu metal in it's various forms is what is needed to stop EMF (hum) problems. It acts as a magnetic shunt, "short circuiting" the magnetic field away from or around the coils of the input transformer. If you look at almost any one of the microphone preamp input transformers in any of the classic (and not so classic!) consoles, you will find them in that mu metal casing. Not copper.pucho812 said:pot them in a copper end cap. We did that back in the day at a place I used to work at. We had the transformers custom made locally and then potted them like you would a 990/2520, etc for shielding purposes in a copper end cap. For a while we had people asking us about nibco transformers. Nibco is the company that would machine the copper end caps we picked up at Home Depot.
warpie said:What about power transformers? What's the best material to shield them inside the rack?
