I think what voltage is applied to the capsule to bias it will probably be more significant?
I have taken a cheap Chinese LDC capsule and applied c.60 volts DC to it.
Taking the same capsule, and applying 3 or 4 volts of RF AC volts at 8MHz instead, and it seems to 'sound' different...
(Although I'll be the first to say that observation is subjective, and I can't actually measure any differences, with my limited test kit).
I think capsule material - all other things like resonance, tension and backplate patterns being equal - is probably a bit down the list of significant factors in determining how the capsule 'sounds' ?.....
