sounds like the engineer is not an engineer, at least not a capital "E" P.Eng. which a lot different that a small ' e' engineer with a diploma or certificate in recording arts. Proper Vu readings are still critical if that is the only reference... If used properly, they are just as meaningful as any PPM. One can learn to translate where an RMS Vu will deflect at any given frequency, transient content or amplitude.
It takes proper training to be able to translate RMS Vu readings. It is a lost art and has thus become trivialized...sorta like calibrating analogue tape machines....it is critical but often ignored in modern times.
PRR said:
> VU meter at preamp outputThe VU meter is BAD for even guessing at peak levels, which is all that matters with >12-bit digital systems. VU meters are now just decorations.
