How to test a power TX?
monty
Active member
Whats a proceedure for checking if a torroid power TX is blown or not ? thanks.
Check for continuity (i.e. connection) through all windings to find broken connections. Check for isolation between individual windings.
Then:
Power on the primary, leave secondary unloaded, wait an hour or two. If transformer gets hot to the touch (more than say 60degrees C) there may be a partial short in one winding somewhere.
Jakob E.
continuity seems to be ok. However with 240V on the primary, I am not getting any voltage readings on the secondaries...
On would presume its time to bin it ?
Does this transformer have dual primaries?
Verify that they're connected properly. If one is backwards, it'll cancel the other.
Byron Jacquot
Write your reply...
