MCA SP1 (MXL603 circuit) noisy (static storm) while "warming up". Where to look?
777funk
I have a couple of these and both work pretty well. But one seems to take about 30 minutes of being on with Phantom Power to lose this static storm noise (at least as loud as the signal). It doesn't go away by knocking the mic into my hand like a bad solder joint sometimes may. My guess is a bad electrolytic cap somewhere. Am I on the right track?
    163.5 KB
    4.8 MB
    5.7 MB
When you blow into the microphone, do you speak loudly up close, does the signal break?
You should thoroughly clean the pcb and the components at the jFET input, with isopropyl alcohol, but not with cotton wool, lint remains, thin threads stuck, impregnated with residues. Over time, oxides appear that compromise proper operation.
If the cleaning doesn't work, only then move on with other investigations.
Depending on the test with high SPL you can appreciate if the capsule is defective.
Got a voltmeter / multimeter?
Yes, I do.
It doesn't seem to change it by speaking loudly into the mic. I do have another capsule. That may be something to try out as a test.
You could check the voltage between ground (chassis) and the D3 / C11 / R9 node, see if, by any chance, it ramps up unreasonably slowly (correlated with the low/distorted signal period).
In this case it's actually like a static storm in the background (as opposed to low signal and distorted). I was thinking I had a recording of it and I do somewhere, but can't find it. But sort of like pink noise as loud as the mic signal (vocal, guitar, etc).
