> Wow. That cam is really something. Is it for mechanical linearization?
The dial is log scale.
The pots are Linear.
Sure you can get "Audio Taper" pots which are "sorta log", but it is a 2-decade range and we only need one decade. And the curve is really two linears. And the accuracy and calibration may be far worse than 10%.
There used to be True Log pots accurate enough to calculate canon trajectories. Even H-P couldn't afford to put two on your workbench.
So they used plain old good Wirewound. Very consistent, very Linear.
And worked that wonky cam to re-curve the dial.
It seems to have a third pot on the dial, a direct coupled 5-cent trimmer. It seems to fudge the peak detector threshold. That whole end of the rig is something which shouldn't oughta work.
I suspect a mechanical obsessive would have a more specific word than "cam". The two scrolls are linked with two cables. If they had teeth, it would be gearing, and yes there are scroll gears (and mind-bending puzzles setting up the tooth-chopper to make them).
> never underestimate the utility of contact cleaners.
Old disused H-P gear ALWAYS needs contacts cleaned, and often needs mechanical lubrication (as I think you found).
One of my 200ABs, the dial just would NOT turn. I soaked it in oil, and solvent, but finally had to hammer the shaft out. With the shaft exposed, it cleaned up easily, and now works fine.
Of two 200ABs and a transistor ACVM, lube and clean covered most problems. One also had a broken 6SJ7 heater, the other had the electrolytic in the signal path go open.
I went around the 200AB power supply on the assumption that the filter caps must be bad by now (both are over 40yo). Could not find any for-sure change in hum or stability.
My current problem is that I lost the screws to hold the older 200AB in its case, and it keeps trying to escape nose-down on the floor.
My Tek 'scope has also gone intermittent, and I can't find the range switch. This 'scope is WAY too fast for me; I'm happier inside my 15MHz Leader or better yet my 19KC DuMont (aint much to go wrong in there).
My General Radio AC VM also needed contact cleaning, a LOT. But it has a unique extra problem. The regulator tubes (large neons) have a half-life. Starting voltage is reduced by a pinch of radioactive dust. It's at the age that I have to open it up and check to see if the VRs lit-off or not. Sometimes patience (or heat) helps. That gives me time to clean the contacts some more.
I also recently brought a "24W" gitar amp, untouched since the 1970s, up from 6W to 13W just by cleaning contacts. New tubes found yet another watt, but the main problem was contacts.
