HT SMPS
Norfolk - UK
I just took delivery of a SUNYIMA EC42 SMPS transformer:
https://www.aliexpress.com/i/32495030305.html
Because I still think it is worth investigating creating a few 100mA of tube HT from a chunky 12V heater power supply (also SMPS). Then I found this:
https://www.aliexpress.com/item/32969027567.html?spm=a2g0s.9042311.0.0.3da24c4dRb1Pdb
which is basically a kit to build pretty much what I am thinking of. it will need some mods to close the loop but it should be a good basis for experimentation.
Whilst looking around the same site I came across this:
https://www.aliexpress.com/item/32997695785.html?spm=a2g0o.productlist.0.0.3e1f4615NdABLp&algo_pvid=26739ab4-b507-42db-ada0-8d2fd48b55b2&algo_expid=26739ab4-b507-42db-ada0-8d2fd48b55b2-0&btsid=e0c38663-5fcf-48e7-acdc-78c4ed0993f6&ws_ab_test=searchweb0_0,searchweb201602_6,searchweb201603_55
which supposedly takes mains input and provides 265V dc at 150mA and 6.3V dc at 4.5 amps. I think I might buy one just to see how it is done.
:eek:  Interesting!
One of the reviews (2nd one down) said they had an issue with the heater supply not performing up to spec from what I understood.....
scott2000 said:
:eek:  Interesting!
That is correct and it is a common issue with switched mode power supplies (rather than a fault with them). The problem is inrush current in cold heaters is several times the nominal value. This means if you put 4 amps of heaters on a 4amp SMPSU it will immediately go into current limiting at turn on because it is being asked for 8 amps or so until the heaters get hot and their resistance drops. Exactly the same happens with current limited linear supplies (I know because it happened to me).
A lot depends on the current limit value. If it is high enough then the heaters will start to warm, their resistance will increase and eventually the power supply will come out of current limit. However, many power supplies (both SMPS and linear) set a very low current limit. I had a reputable linear supply that took nearly 30 seconds to exit current limiting  - fortunately I was able to tweak its current limit so this dropped to 10 seconds.
Many modern SMPS use what is called hiccup mode for current limit. This results in bursts of full current being applied and it will much more reliably exit current limit. Even so, I still rate my heater SMPS at twice the rated current for the tubes.
Bottom line is although this SMPS can output over 4 amps at 6.3V you can only reliably expect it to fire up 2 amps of tube heaters.
What I don't like about all these variants around is that the heater taps aren't conducive to elevation or hum suppression techniques. For dialled in efficient HT though, without big dropping resistors burning; the attraction is great. Followed by a big choke of course!
R
R
I am thinking of this primarily for HT. I need getting on for 300mA of really low noise HT for the tube mixer I am building right now. For a linear version I heed some serious RC filtering followed by a regulator. That is some serious iron, PCB real estate and a far bit of heat. A switcher would be much smaller, could be followed by much smaller RC or LC filtering and the regulator would have a fixed input voltage which simplifies thermal design.
Theres one on ebay I havent spotted before ,
https://www.ebay.com/itm/NEW-500W-0-300V-DC-Output-Adjustable-Switching-Power-Supply-CNC-WITH-CE/172107145711?hash=item281262a1ef:g:zNgAAOxy69JTDg-b
It has a lot more current capacity than you require  and a fan which might not suit either .
That is a new one. They seem to appear every now and a gain but as you say the power output is much more than we need. I wonder what applications they get used for?
You can order this 500w package in a range of voltages all the way  from 12  to 300 v , so it seems  likely they are able to custom wind the switcher transformer  and use applicable components for the voltages/currents  required , the other thing is they claim CE approval, I'm not sure if thats applicable to your build or  not .  Maybe they have some more modestly sized units they can do custom voltages for you on .
https://www.ebay.com/itm/NEW-HQ-300W-300V-DC-1A-Output-Regulated-Switching-Power-Supply-CNC-WITH-CE/173851134210?hash=item287a55c902:g:zNgAAOxy69JTDg-b
same supplier ,
R
What hum?  Filaments are 6.3v DC.
Ian, I am anxiously awaiting your review of these supplies.  So anxious that I may order one myself ;-)
The available HT current from these is much higher than I would ever need. My favourite contender at the moment is the Meanwell one that outputs 300V at up to 500mA. I bought one ages ago and when I get time I plan to add the old FET/zener regulator on the end of it to drop the volts to 250V and get rid of any mush:
https://www.meanwell-web.com/content/files/pdfs/productPdfs/MW/ELG-150-C/ELG-150-C-spec.pdf
ruffrecords said:
Hi Ian,
I was referring to this one.  Often clients have a couple of old RCA, Langevin, etc tube modules they want racked up.  This is way more than enough for a pair of tube preamps, but it is inexpensive so I wouldn't feel bad "wasting" it on smaller projects.  I'll look around the site for a smaller one though.
Mike
One of these arrived in the post the other day and I gave it a quick test last night. I was a bit disappointed. No loaf voltages looked OK at 6.27 and 260V. Then I loaded the HT with 5 33K in parallel and the voltage dropped to about 240V - the current draw was about 35mA. I checked the ripple on a scope and was disappointed to see it was a 1.5V pp sawtooth at 50Hz!!!??? It ought to be 'regulating' properly at 34mA load but I will try with a heavier one in case it is in some sort of hiccup mode.
ian
Holger said:
Damned, I've ordered the same type. Is it a complete waste of money?
Right now I do not know. It appears to be well built with an adequate heat sink. The HT side has a couple of 22uF/400V smoothing  caps with a small inductor between them. According to my calculator, with a 35mA load that should have 8V pp ripple at 100Hz on it if it was a regular linear supply so the board is clearly doing something. I may have a faulty one or it may need a heavier minimum load. I need to conduct more tests with a bigger load.
IMO, you should load the 6.3V output also to get good regulation just because this voltage is the reference for the feedback and control of primary switcher.  Anyway, this PS looks to me too simple to be good and reliable.
How do you know this? I it very hard to see the top side PCB tracking so I have not yet traced out the path the the opto isolator.
Simple, good and reliable are not necessarily mutually exclusive. There are a lot of SMT components on the bottom of the PCB including a 6 pin DIL chip.
