Potato Cakes
Hello, everyone,
I recently found this: . The guy goes over how take the hum from the heater line and inject it back into the audio path to cancel itself out. I've attached a screen shot of his final schematic. So I had to test it out myself. I have a 5W single ended tube amp that has a solid state rectifier. The heater winding does not have a center tap but the schematic uses two 100 ohm resistors to artificially create one. It was already pretty clean but there was a bit of hum in it which didn't bother me when playing through it. I made the modification as shown in video and now it is completely hum free.
So I moved on a Matchless Spitfire that I built. It has a low level of hum but it so far below any guitar signal that is connected to the input that it never mattered to me. But there is still a hum and I wanted to see if I could repeat my previous success. Without thinking I made the same connection from the center tap of the heater winding (the schematic doesn't show one but my transformer does have it) to the cathode of the two EL84's and then a 4k7 resistor in series to the phase inverter's cathode. It made a sweeping oscillating sound that was very loud. I double checked the schematic and saw that there is 63V on the cathode of the phase inverter, so I couldn't use that connection point. I then tried a number of different connection points like the cathode of V1 but nothing made the hum go away like in the first amp. The "best" result that I found was connecting to one of the grids (pin 2) of V2, which is the phase inverter. The hum was completely eliminated but so was over half of the output. The guitar signal still sounded as it should but I had to turn the volume up most of the way to get the same output. Also when driving it hard it didn't breakup as smoothly as before. So I'm wondering if there is a way to use the hum cancelling circuit as shown in the video for the Matchless circuit? I've tried a number of different connection points but none improve and some create more problems. If there is a way to add the cancelling circuit in this amp it is not obvious to me. Not a big deal as I can record with it as I have it now, but for sake of possibly learning something I'm wondering if there is way to make this completely hum free using the example in the video.
Paul
Paul
