Breezio
squarewave said:The resistance between grounds should be basically zero (maybe a few tenths of an ohm just because of oxidation on metal surfaces and probes). Check resistance along the way. Does it increase across a particular solder joint?
When the amp is on I measure 13 ohm and when it's off the then values (for every point) go back to the tenths of ohm.
What is that supposed to mean?
