dagoose
Hi all!
I'm in the middle of testing and finalizing my stereo extended pultec but i do have a really annoying 50/ 100 hz mains hum.
I read some stuff about it that the 25v voltage to the tubes might be to high, mine reads about 270v after the resistor (so on the tube) and 300v before the resistor which is the standard 3k3, i think that is a bit high isn't it?
Do you think it will help to change the resistor to a different value to lower the voltage? and what resistor should i use then?
When i power down the machine the hum is instantly gone and i have a perfectly working EQ for a couple of seconds so i don't think it's a groundloop hum.
I tried moving the toroids without result, no differnce at all...
I also tried to reverse the second transformer polarity with no result as well..
When i remove one of the tubes (when i have just one channel connected) it gets a bit quieter.
I'm waiting for the input transformers to come in but i don't think that will solve the problem completly.
Anyone?
Anyone?
