ioaudio
samuel, look at jacob´s layout i posted above.
Yes--if you have it digital you can check the waveform as well, similar to a scope but with much limited bandwidth (which should probably not be much of a problem for this case).You mean run the 6.3 V voltage into an analog input (could also be a mixer then) to check if that gives a flat clean signal?
I don't understand, how the tube could give sound with no heater voltage ?removing the fuse just removes the 6.3v (in my case the way i connected right now) and when i power down all power is shut down bu the caps slowly empty so sound is coming through for a few seconds.
Oh sure--use AC coupling.My probe is just x1 so i can't measure the 250 V.
