hey thanks, cool gif. yeah, thats a good trick. for prototyping, that is the way to go. only issues for me is that ispreferably machine-placeable and has some additional kind of mechanical capture, not only the solder bond. I found a machine placeable version of bascially the same idea a while back by "emulation technology" with 2 locating pegs in the molding and a vacuum patch but it is either vaporware or obsolete. and it takes up a bit more space. I want to use the little clip-on pins that grip the pcb, or press-fit and take up little space. standard issue on thick film hybrids. I want ideally discrete pins, not header strips, and the mechanical gripping type that keep things in place thru subsuquent reflow/wave operations when the daughtercard gets soldered to the main assembly. any other ideas for a source?
mike p
