@Silvas:
If you're really going to re-work the pcb, and use my advice for the part flipping @input (i.e. aroud the fet gate and the 10gig resistors), then I should add this as well:
When you finally get to the ground-pour around the fet gate traces, don't fill the ground as close to the traces as it is now - better leave some space around (perhaps similar to what you have around the two 100k resistors in the original layout) - so that when the circuit is soldered and assembled, you can use a toothbrush and alcohol and really clean-up the spot around the fet gate, so that there are practically no chances for any parasitics or residues.
