I came to the same conclusion. The Analog Discovery 2 should be fine for frequency response, but not for THD nor noise measurements.Gold said:I’m still getting the hang of it but i like it better than anything I’ve tried so far. I don’t need a low noise floor for a lot of measurements. I figure i can use the dedicated interface most of the time and switch to a soundcard when i need a low noise floor.
For me, the absence of a frontend with calibrated attenuators and physical time base control is a deal-breaker.shot said:A friend of mine has this one
https://www.picotech.com/oscilloscope/2000/picoscope-2000-overview
From what I've seen it's bang for the buck. I was impressed how noiseless his display of audio signal was.
Tubetec said:Thats interesting that the Waveforms software is usable with USB audio interfaces , I know it was a question that cropped up previously .
abbey road d enfer said:I came to the same conclusion. The Analog Discovery 2 should be fine for frequency response, but not for THD nor noise measurements.
Well you got me on this one jacomart. The datasheet does say 8 bits. I'm completely flummoxed by that. I guess to get up to MHz they had to limit the bit depth. It must be that the range setting adjusts the level going into the ADC so it can more fully utilize the very limited bit depth. That does make sense because when I adjust the range on my cheapo Rigol I can hear relays switching inside. And it explains why the FFT feature on digital storage scopes is completely useless. And the waveform in the display is presumably being oversampled / interpolated. At least it looks like it's a lot more than 256 steps.jacomart said:https://www.mouser.it/datasheet/2/403/Tekronix_TBS1000C_09082020-1894344.pdf
R&S RTB2000 ADC res. 10bit 1540USD
https://www.rohde-schwarz.com/us/product/rtb2000-productstartpage_63493-266306.html
Surely the displayed waveforms take a sort of "makeup". A better resolution (10 or even 12 bits) helps in the exact reproduction of signals, e.g. glitches and their settling times. Instead 14 bits are too few for FFT, SNR and THD analysis as the theoretical SNR of a 14-bit ADC is about 86db but unfortunately the number of real bits is lower due to the ADC distortion (the infamous SINAD parameter ) and for this reason the real SNR can worsen significantly. For Analog Discovery 2 in the forum they say that it has a measured SNR of about 70dB, in this case the real number of bit (ENOB) is about 11dB instead of the theoretical 14dB. Oversampling and decimation are a different story but it seems that Analog Discovery doesn't use them.squarewave said:If I ever get a new scope, I'm definitely going for 10 bit. That must make a huge difference in how the display looks.
Agreed. that's why we need to extract and measure separately noise and distortion from a signal. Magnifiers.Tubetec said:The ear is capable of several magnitudes more discerning than the eye 8)
rock soderstrom said:What I didn't know is that Waveforms is freely available and also works with sound cards or USB audio interfaces. Thanks for this info! I'll give that a try today....
Unfortunately it seems to be limited to 16 bit. A USB audio interface cannot measure DC or high frequency signals like digital. So using WaveForms with a USB audio interface is basically useless for anything but a narrow range of low resolution low frequency AC-only measurements.rock soderstrom said:What I didn't know is that Waveforms is freely available and also works with sound cards or USB audio interfaces. Thanks for this info! I'll give that a try today....
For those this is new territory, as it is for me, here's some good info on the subject.
https://www.nutsvolts.com/magazine/article/turn-your-computers-sound-card-into-a-scope
squarewave said:Unfortunately it seems to be limited to 16 bit. A USB audio interface cannot measure DC or high frequency signals like digital. So using WaveForms with a USB audio interface is basically useless for anything but a narrow range of low resolution low frequency AC-only measurements.
I was just talking about the "WaveForms" software. It's simply not designed to handle samples larger than 16 bit because it's oscilloscope software. Even if you could interface the WaveForms software with the chip you cite, it's bandwidth is limited to 100kHz so again, it would not be suitable for MHz digital signals.jacomart said:Could one of the problems be that the ADC filtering cuts at something less than about 0.5*F(sampling) ?
A solution could be the use of a high speed 24 bit converter like the TI ADS127L01 of which there is an evaluation board which costs about 112 €. However, the software problem would remain ...
https://www.ti.com/tool/ADS127L01EVM
JM
squarewave said:Kind of a niche product but just thinking out loud.
And that all makes sense because the scope needs to be able to zoom in on a tiny voltage. So yes it will fully utilize the interface bit depth. But being an oscilloscope the WaveForms code only needs to manipulate and display a relatively narrow bit width. So it would also make sense that the code only uses 2 bytes per sample. Any more than that and it would just be wasting a potentially huge amount of memory trying to process samples at MHz frequencies.Gold said:I don't think this is true. My Native Instruments Konnect2 will do 192K 32bit fixed or float according to the driver device settings in Waveforms. I haven't checked the measurements to see what the real world limitations are but the ASIO driver recognizes this high bit and sample rate interface.
squarewave said:However, maybe the spectrum analzyer can switch to using 24 bit or maybe more. All of the screenshots of the spectrum analyzer window on the digilentinc.com website look like the noise floor bottoms out at around -96dB which would be the limit for 16 bits.
