Identifying polarity
rrs
Wagga Wagga - NSW,Australia
Hi guys I have a tricky one.
I have an Axel Electrolytic that has me a little weary on the polarity. Whilst it has the negative markings down the side with what looks ile arrows pointing to one end It also has has the Long lead on that end (normally positive) and short on the other.
I cannot identify any other features and the datasheet only says "Negative terminal identified" under MARKINGS.
Im 90% sure the negative is the way of the arrows but would like to be much more surer than that.
http://www.mouser.com/ds/2/427/138aml-239889.pdf
It's the blue one above in the picture
hook your DMM to the cap while set in ohms
red clip lead = pos
black = neg
clip leads will match polarity of cap of ohms slowly go up to megohms
if resistance drops instead, then cap is hooked up backwards with multimeter
flip leads and try again
if you need the physics and chemistry behind this, wait for a propeller head to post up,  ;D
