If only two mics... ?
Charlin also mentioned (with photo) in this paper on history of binaural (first PDF below, page 772).
A current and frequent user of the Jeckilin is ex-Decca engineer, Simon Eadon. Shown are a couple of his sessions.
Many years later, Jecklin inceased the dimensions and spacing for less 'mono-ish' sound at low frequencies (see JecklinDisk PDF).
Jecklin (and baffled, head-spaced omni techniques in general) works best on smaller enembles and/or those without a lot of LF content (small to medium size choirs, and chamber groups). For full orchestra they are best combined with widely spaced omni 'outriggers', or 'flanks'.
________
It's worth mentioning that Alan Blumlein described the technique of head-spaced baffled omnis in the '30s! (long before Jecklin or Charlin). Best known for the technique of figure-8s coincident at 90 degrees, he was also the first to describe baffled omnis.
  • stephan_paul_binaural.PDF
    6 MB
    386.6 KB
    555.6 KB
  • JecklinDisk.pdf
    37.9 KB
    62.3 KB
Hi guys
A bit off topic but not really if you consider that searching for "only two mics" leads to keep on searching and try things...
So in this spirit I bought 2 PUI5024 electret capsules and just set them up according to the "Simple P48" project : one 150KΩ resistor and a good quality capacitor (I used a Panasonic FC 4,7uF@50v) for use with phantom power and the result is really amazing ! at first audio test (with the capsule not yet installed in the XLR connector so just hanging at the end of a one foot audio shielded cable > just for a first quick audio test to check if I have sound... and I do !)
This weekend I will do some more audio tests to compare with my Line Audio Omni1 pair (voiceover & acoustic guitar something like 5 feet away > ambiant recording) and will post them here asap (in a blind test of course :giggle:)
Thanx to @ricardo who guided me to this project that I didn't know and provided me the good infos & links ;)
To be continued...
    116.1 KB
[EDIT: Already posted in #262 above as Stephan Paul article]
An interesting academic journal article that covers several devices, including the tete Charlin:
  • Binaural_Recording_Technology_A_Historic.pdf
    6.6 MB
