Igor CRM - Volume change up instead of down.
tomerttb
Member
Hi Guys, I had Igor CRM for 2 years i had no problems with the unit, last month it was sold to a guy in the US, unit was on Europe 240V and now its on 110V.
initially the unit worked good but now it seems to have a problem.
Sometimes "randomly" when you change the volume down (Slow or Fast, does not matter) the volume jumps a DB up instead of down.
If you continue to change the volume down its ok and the numbers goes down.
Any thoughts on that issue ? :(
Thanks a lot
Tomer.
