When making an impedance balanced output what is the best way to match resistors? The buildout resistor goes from the opamp output to xlr pin 2 and a matching resistor goes from xlr pin 3 to ground.
The output impedance is usually stated as the buildout resistor value. Isn't this an approximation that assumes the output impedance of the opamp is 0 ohm? If you are trying to match the impedance to ground matching the resistors will have an error.
If the actual opamp output impedance is 0.1 ohm I guess it doesn't matter but if it's 1 ohm and the buildout resistor is 50 ohm that's a 2% error.
Do I need to worry about this?
