These are very strange specs for mic inputs.Sorry, mic booster + impedance switch is for Metric Halo 2882 with Mic Inputs: 200 kOhms (Balanced).
Looks like a very bad compromise to make a "universal" input.Strange, indeed!
A 10dB transformer is probably not useful before an existing preamp, but would be useful if you control the circuit, e.g. in front of a tube or jfet circuit with very high impedance.is there any use of using putting +10db transformer before preamp?
In most cases, reducing the impedance the mic sees results in deterioration of sound.
As the posted video says, it is shocking how it changes the sound, but he neglects to say that reducing the impedance always results in worse sound.
It has been clearly demonstrated that dynamic and ribbon mics benefit from the largest possible impedance; this has been known since the inception of ribbon mics in the 1930's.
Condenser mics may not be as sensitive to loading than other types, but in any case, there is a common consequence: the level drops, thus reducing S/N ratio.
This kind of variable load acts only in one direction, it does not "open" the microphone. It is only capable of choking it.
I find it pathetic this trend to sabotage sound with that kind of device or introducing distortion, when generations of engineers have pulled hairs to improve objectively the performance of equipment.
That's an interesting article, although it somehow misses the point.This seems a little strong… it doesn’t seem out of the realm of possibility to me that some ears prefer some mics with a lower load impedance. In particular, some people think the SM57/58 sounds better into ~600 ohms. IIRC it has to do with damping midrange resonances.
https://web.archive.org/web/2008120...dingmag.com/resources/resourceDetail/330.html
IINM, the OP proposes to build a load box. Mic booster comes later in the discussion, showing he already has one.This doesn’t have much to do with what OP is looking for though - why not build a Cloudlifter?
Does anyone sells DIY kits for Cloudlifter aka mic booster?This doesn’t have much to do with what OP is looking for though - why not build a Cloudlifter?
There are a couple of Cloudlifter 'clones' that cost a lot less than the original -- so cheap in fact that it's probably not worth trying to build one !Does anyone sells DIY kits for Cloudlifter aka mic booster?
I suggest you search in this group for cloudlifter. there are at least 3 extensive threads about them.Does anyone sells DIY kits for Cloudlifter aka mic booster?
Apparently, it uses a front end that's very similar to Cloudlifter/FetHead, combined with a Schoeps output arrangement.Here are the guts of one of the AliExpress Cloudlifter clones. Four transistors (probably JFET like the original) but way more parts otherwise!
ha go figure, looks like someone knew what they were going for?!Apparently, it uses a front end that's very similar to Cloudlifter/FetHead, combined with a Schoeps output arrangement.
