Yes, rumors of the demise of the 600-ohm load have been greatly exaggerated :wink:
In most cases, I design the outputs of my gear to be capable of driving 600 ohms to at least a reasonable level without excessive distortion. Of course, better results are usually obtained with a higher impedance, "bridging" load--although when using transformer-coupled gear with a nominal 600-ohm secondary, you may have to load it with 600 ohms for flattest frequency response.
As far as output impedance goes, lower is usually better. The cases in which you actually want a 600-ohm output impedance are relatively rare, the notable exception being passive EQs or filters that depend on specific values of source and load impedances. Even then, it's easy enough to add buildout resistors to low-impedance outputs when you need to satisfy that condition.
I agree with John that, at the cable lengths we usually deal with in studios, at audio frequencies, characteristic impedance of the transmission lines is usually something we don't have to try to match. I work in broadcast, so I do encounter those cases from time to time when cable lengths are significant with regard to signal wavelengths (e.g., STL over landlines of a mile or more in length).
