M
mattiasNYC
Guest
Hi guys,
I registered a long time ago but life got in the way of DIYing and didn't get very far. I'm now in need of a box to re-route or bypass a signal and ultimately do bass management.
I have 6 outputs from my LYNX TWO-B sound card. These outputs are usually L, R, C, LFE ("sub"), Ls, Rs. All are balanced line level and go to powered monitors. Subwoofer has L/R inputs and L/R outputs. It has a variable XO, phase invert (or whatever), and volume control. It is intended for L/R to go through the sub for a 2.1 configuration, or the LFE to go to either L or R only in a 5.1 or higher setup.
When using my DAW I'm able to work by treating the 5 speakers as full range and only sending dedicated effects in LFE channel to the sub. But I'm also able to do software bass management to check my work should I want to.
Watching movies my computer will decode to 5.1 but not bass manage (as far as I know). It's actually ok for most viewing and I don't have a big problem with it.
But listening to music in stereo I would like to extend the range using the subwoofer.
Short Term Solution: Simply build a switch to alternate L/R between going straight to speakers for 5.1 use, or into sub for XO and from there to speakers. Note that channel 4, LFE, is not sending anything in the stereo scenario. The build needs to be relatively cheap and simple to build.
Long Term Preference: Bass management for 2 to 5 channels.
Questions:
1) I'm thinking that my L/R will have a switch that would switch between sub/XO stereo and bypass for 5.1. If I do this I suppose the output of the sub is where the L/R would "reconnect" in bypass. So do the sub-outs need to be switched out in L/R bypass mode? And is a dpdt switch or rotary fine for this? Is anything else needed really (I'm thinking about potential pops when switching etc)?
2) My LFE (output 4) would have to be going into one of the sub's two inputs for when the L/R signals are bypassing the sub and sent straight to speakers. Would having this connected to for example Left at all times be a problem? (remember, this input would not carry signal to be summed with Left, it would be either LFE or Left).
3) Has anyone done any bass management around here? I've looked but haven't seen any finished projects.
4) What do I need to keep in consideration - if anything - in order to make a move to bass management easier if I start out with a simple switch only? (like, if switching more channels is easier and/or cheaper with relays, do I benefit from using that from the beginning? etc)
Thanks if you made it this far!
Any help is appreciated,
mattias
Questions:
mattias
