[quote author="Samuel Groner"]
Not necessarily, in fact most probably not.
Thanks for correcting me. Not sure I truly understand this - if I look at the AD797 datasheet (o/l gain curve), it seems like a global feedback problem to me, no?
Samuel[/quote]
Well of course I could be full of Sh*t :razz:
Actually, looking at it just now, iirc the new datasheet is quite a bit more detailed than the one I saw, which merely had the discussion (retained in the new one) about the lack of damping with the low r sub bb' input transistors. The inclusion of the open loop gain/phase plots I don't recall from the time I used the parts (about eight years ago).
So---it looks like the
effect of the parasitics is to boost the open loop gain, effectively, while the rest of the amp is going over the cliff in terms of stability margin. So my analogy to grid stoppers is somewhat bogus, at least inasmuch as the tube situation is a local oscillation and not a global one.
I used the parts with a gain of +2.00 (+6.02dB), and as I say added to the fun by having additional phase shift, however small, in AD811 buffers so I could drive some heavy loads. I devised a complex compensation network empirically, and the beast was still on the verge of getting tetchy.
