Allright then, I've made measurements on the circuit I had proposed (with OEP transformer and TOKO inductors), and it does *not* work.
The impedance transformation sort of works, i.e. I get the right resonance frequency and the right impedance. But I also get unwanted low impedance at the low end (where the transformer's own inductance isn't enough) and at the high end (where the transformer's capacitance creates a bypass path).
Bottom line is: transformation of a series resonance circuit doesn't work (unless you have a really good trafo maybe). The only way to use low inductance values would be transforming the whole signal down (trafo with resistive load), then do the filtering low-impedance (a la pultec etc), and then buffer it and amplify of transform it up again.
Too bad that the shortcut of just transforming the resonator is not - would have been too good to be true!
JH.
JH.
