pasarski
- Joined
- Jan 29, 2010
- Messages
- 415
These have been discussed before, and I'm totally out of my depth on the subject, but I still decided to post my findings. Maybe it's of interest to somebody.
So I was trying to simulate the voltage booster of Behringer B-1 using this schematic https://groupdiy.com/threads/behringer.44991/post-1163043. It was quite difficult to get running correctly and while investigating I found out that similar circuit has been used by Schoeps and it's been copied to many China mics. This is the simplified version of the circuit using only a simple ideal voltage source for Vcc. The inductors are touching each other in real life so I coupled them. (Don't know the actual coupling coefficient and used 0.7 which seems plausible.)
This is the output with 10V input:
Zoomed in to see the AC -component:
I remember reading that in some Chinese mics the inductors are not physically coupled (I think it was about U87 copy though) so tried it without the mutual inductance statement and got lower voltage, but still a hefty boost:
Zoomed in. Higher frequency and little bit less AC (is it ok to call it "ripple?)
At some point while troubleshooting the sim I started to suspect the schematic is wrong and tried to trace an actual B-1 converter board,and while (unsuccesfuly) doing it, started to suspect that the other end of the other inductor (L2 in my schematic) is floating. I know that it would have not been super hard to confirm that, but my brain was already hurting, so I went to the sim and tried this kind of schematic. While simulating transformers I've learned you can't leave an inductor floating in LTspice (at least I can't get it to work) so I connected it to ground instead and found out that this circuit indeed boosts voltage, but only with the mutual inductance statement included:
Not as much boost though, but still a nice 4X:
Marginally smaller AC component:
That's the finding. I understand that I didn't find anything useful. No sense doing it like that if you can get more boost with correct wiring. Also I understand that this is simulation and there might be misconceptions in my sims. But maybe someone with more knowledge can find some usefulness in it, though I doubt it.
