problem understanding with DC converter 60v schoeps CMC5.
mudevilo
Member
FRANCE
Hello everyone.
I have a problem understanding the schematic of the Schoeps CMC5 preamp...
excuse my ignorance!!
But I don't understand how we get 60v of bias for the capsule from 6.1v as shown in the diagram?
I did a simulation with LTspice which absolutely does not give me 60v voltage...
if someone could explain it to me?
Thank you to all of you.
You can think of the concept in two parts...
• A Hartley oscillator, typically running an ultrasonic frequency.
See here for some details: https://www.electronics-tutorials.ws/oscillator/hartley.html
• A voltage multiplier, which takes the oscillator output signal, and then 'multiplies' and rectifies it to obtain the higher DC voltage required.
See here for some concept notes: https://www.electronics-tutorials.ws/blog/voltage-multiplier-circuit.html
thank you for this documentation...
I will read this carefully.
In the physical circuit, those two inductors are usually placed side-by-side, so there is some magnetic coupling going on. Perhaps you need to add that in your simulation?
https://en.wikipedia.org/wiki/Inductor#Energy_stored_in_an_inductor
Hartley oscillator - Wikipedia
(although i could be wrong about the exact type of oscillator this is, i'm no magnetics expert)
A while ago, I simulated a similar circuit of the MXL770/990. With a coupling factor of k=0.1, I got approximately 48V on the multiplier output. Output voltage varies with different k values, i.e. distance between the coils.
Jan
If you have room, you might like to consider an alternative arrangement for a DC voltage multiplier which doesn't use inductors at all?
So there is no 'iffyness' that can come from the polarity and orientation of Hartley oscilllator inductors.
It's based on circuits in this artlcle from the 1980s : https://gyraf.dk/schematics/Voltage_multipliers_with_CMOS_gates.pdf
I use it for my OPIC mics. (See the bottom half of this PDF: https://www.jp137.com/lts/OPIC.41.pdf )
It's used in the Alice OPAs mics from Jules Rykenbusch as well ... and Rode use the same concept to derive polarisation volatges in some of their LDC mics (eg.NT1).
Jan
In the case of CMC5, what are the values of Dr1 and Dr2? they are not indicated...
Are these values critical or not?
