CJ
it is a hassle to un-rack a mic pre in order to test input and output transformers as well as plate inductors,
so we kludged up a fixture which will allow us to check all of the above,
this is for tube related iron, based on a V72, used the same layout but expanded it a bit to make wiring easy,
still have to get some alligator clips to insert into the banana plugs for easy hookup,
has an XLR cable for a microphone and a 1/4 inch jack for output into a mixer for listening tests,
phantom would be nice, maybe we will add that down the road a piece,
EF804s for input and EF86 for output since we want to go cheap and not waste the whole tube caddy on this thing,
plate inductors are best tested in the circuit in which they are used in order to get accurate results for inductance measurements,
going to power it with an external supply
we also have wound a Peerless K-241-D input on a 625 EI core of super Q that performs as well as the original but has more headroom and bass, the stock Peerless is rated at 8 dbv input if i remember correctly, the 625 EI version will take about twice that level,
here is how it came out, input on the left, choke on the top, output on the right,>
