I'm going to rack my Spectra Sonics cards. In the manual they suggest using 150R transformer primary for dynamic mics and 600R for condensers.
I'd like to put a stepped T-Pad before the input transformer. The problem is, all resistor values are different for 600R and for 150R. Is there any simple solution to this?
I thought of using 4 pole 12 pos switches but they are very hard to find. I also thought of using relays but this promises to be very expensive.
Maybe it's possible to work out some circuit that switches in additional resistors in series/parallel. It looks like all the resistor values should be 4 times less for 150R, I just can't find out how to do it simply.
Or maybe I'm going in the wrong direction and I should just leave the 600R T-Pad and switch the primaries only? I don't think it would be a good solution though.
EDIT. It just came to my mind that I can put a T-Pad after the input transformer... Hmmm, would it be ok though...
