I have sad news: Andreas Grosser, who did this mod, is no longer with us. He passed away in his sleep, unexpectedly, aged 65. I didn't know Andreas personally, but this info is from someone who was in close contact with him.
Really sad news. Ruhe in Frieden Andreas.I have sad news: Andreas Grosser, who did this mod, is no longer with us. He passed away in his sleep, unexpectedly, aged 65. I didn't know Andreas personally, but this info is from someone who was in close contact with him.
Just changing the fet will affect the negative feedback network. The values might be the same but depending on the fet/bias filter might vary A LOT!It's 3.3pf in the modded mic, not 3.9pf.
No, the output coupling cap was kept, a cheap Jamicon 1uf/63V.
I wonder why the mic seems to have more low end than before the mod, since the filtering network there wasn't change. Can the added feedback cap have this effect?
Interesting, so does this only depend on FET type or would there be variation from - say one 2N3819 to the next - since all of them have to be individually biased (and I think I even read about selecting FETs for U87 circuits somewhere)?Just changing the fet will affect the negative feedback network. The values might be the same but depending on the fet/bias filter might vary A LOT!
If it helps, my experience has been that when contemplating different JFET's, it's important to draw the intended load line on a typical VDS/IDS plot, then consider how that same line will look on the replacement JEFT. Often, tweaking of drain AND source resistances is in order.
To make things more difficult, JFET parameters across a handful of the SAME DEVICES can span a 300% range across common parameters like gate-source off voltage, IDSS. For example, for the J305 device, VGS(off) can span from -0.5V to -3V, and IDSS can span from 1mA to 8mA! For the 2N3819, VGSoff can be anywhere between -0.2V to -8V, and IDSS can be anywhere between 2mA and 20mA! This often means that you need to buy a handful and measure the one that will work best in your intended circuit.
Thans for that link and thank lord we have waybackmachine.
What would be a good trimpot value to try in a U87 type circuit? 10k? 50k?Thans for that link and thank lord we have waybackmachine.
