analogguru
Now lets see:
The iSK Little Gem uses exactly the same circuit as the Samson C02 - except that Samson used a 22pF to ground at the gate of the FET.... I don't know why but maybe RuudNL has an idea. You can try to put this capacitor there and see what happens.
The nonsense I am talking about can be seen in the drawing of the output stage where two 27k resistors are mounted from emitter to collector.
In the original circuit from Schoeps these resistor are mounted from Emitter to BASE. I think a cloner became confused with the pinout of the transistors and the rest of the cloners were following...
Sonotrad is using a very similar circuit (including the nonsense) except that they use a J305 (instead of the 2SK596) with a 1GOhm resistor from gate to ground. Maybe this cures the noise....
