Hi there, I am searching for any idea with a rare problem that I have with a pair of SRX 828SP. The SRX 828SP doesn’t increase its volume although the gain potentimeter is the maximum value +12dB showing in its screen.
To me this trouble look like preamp board problem (no amp section, the power amp is ok because I tested with a preamp board assy only from another good one SRX 828SP unit!). I have attached the pic of the preamp board that I think the problem is.
I connected this SRX 828SP to my laptop pc with HiQnet JBL software and here I can send the pink noise normally but when I send the audio signal doesn’t see in the bar level indicator in the control software!!
I have changed the two input Opamps M33078 (U1 and U3) for new ones but the problem is still there.
Do someone have the schematic of this sub bass JBL unit?
Does anyone have had this same problem before?
In the worst case I would have to buy two cards that according to JBL are part number 5044210-04 PCB,ASY,Input,Sub,AV, but I don’t find any seller of them.
opacheco
opacheco
