JohnRoberts said:
dcollins said:JohnRoberts said:
What all that in the article about "basic digital problems" or "phase-shift above 2k4?"
http://www.gambleboards.com/Article.htm
DC
DC
With the risk of starting a flaming war again on digital conversion...:
Jim states that at lower-level signals the relative distortion of the A/D converters increases. This is due to the fact that there are relative less bits 'active' to describe the signal-waveform. On this point I agree with Jim Gamble, the effect is of course more dominant on a 16-bit system than on a 24-bit system.
I don't understand his 'phase-shift above 2k4' remark. But of course a DC-coupled system-chain introduces less phase-shift than a chain with decoupler-capacitors.
Jim used in the EX56 only MKT-capacitors in the audio chain and the complete channel stages are DC-coupled with servo's.
Theo
Balijon said:Thanks for sharing this link John.
Most interesting view on 'ism's' and reality context.
I am interested in how Jim applied the D/A's as DPOT's in the EQ sections. I have seen solutions with using multiplying DAC's for volume pots that are more clean than VCA's. (like the Hoef-Automix HF-16)
In the meantime I am still hunting for the 'old-all-analog' EX56 schematics.
Theo
JohnRoberts said:PS If you are seriously considering buying one, it seems a fair question to ask Gamble if you could then get access to schematics. Surely a console of that complexity will require repairs and support.
Balijon said:Jim states that at lower-level signals the relative distortion of the A/D converters increases. This is due to the fact that there are relative less bits 'active' to describe the signal-waveform. On this point I agree with Jim Gamble, the effect is of course more dominant on a 16-bit system than on a 24-bit system.
