Hi!
This is my very 1st posting on this forum.
Just recently purchased a home made soft starter for my 3kW toroid transformer over the internet and it doesn't work.
What seems to be the problem is that the triac never kicks in to take over the conducting of current from the power resistors.
As the seconds or minutes pass by the resistors get warmer and warmer while the triac stays on room temp.
The household appliance (food processor) that's connected to the toroid won't even move if it's loaded with veggies, it does spin if I leave it empty but I can sense that there is no real power behind it.
Btw., my toroid is a 3kW one not because I have a near 3kW powerful appliance to work with but because when I needed a 2kW transformer, I couldn't found any, so I purchased this one. But the max. load that I put on the toroid 5-10 seconds AFTER I turned the toroid on is not bigger than 1800 Watt one.
I needed a soft starter solely just to start the toroid because 1 out of 5 times it triggered the circuit breaker of our apartment.
(I'm using the toroid to get 120V for several of our household appliances that I brought home with me when I moved back to Hungary from the US.)
But going back to the subject of the soft starter, the guy, who sold me the unit over the net isn't too friendly, and not willing to go through some troubleshooting with me .
Today I posted a similar message on a similar forum in Hungary and I got several answers but I'm not sure if I got the right answer from there since nobody seemed to be strong on triac based soft starters (no relay).
I was told that the soft starter that I posted pictures of on that forum shouldn't even work, it's a bad design. (while the guy who made it and sold it to me told me that he is an electronic engineer, that I have no way of verifying. )
Someone on that forum created a circuit diagram based on the pictures of the PCB and the empty PCB drawing that I did in Paintshop Pro and then suggested 3 mods that would make that circuit work.
So, I thought I'd post the circuit diagram and the suggested mods here and ask for your opinion: whether this soft starter as it was designed shouldn't work indeed and the mods would make it work indeed?
The URL link to the pictures: https://tinyurl.com/o659qs7
Now, normally it is not my habit of posting question about someone else's opinion on a different forum, I decided to that in this case because I'm in a situation where couple of forum members stated that the circuit that I just bought from an electronic engineer shouldn't even work and at this stage I'm still not convinced that I was dealing with a crook.
George
George
