Hi all,
The gain on my KM56 seems a little low. I was having a problem that I was able to fix, and now it sounds excellent, other than that the gain is low. I should add it seemed low before the present problem which turned out to be a resistor that worked its way loose on one end. I was wondering about the output transformer strapping - if it's strapped for 50 ohms the gain would be lower than if it's strapped for 200 ohms. Is that correct or is it the other way around?
:thumb: :thumb:
:thumb: :thumb:
