KM84 DIY Body & PCB kit – CLOSED
AW_music said:
Can someone please explain me exactly where to intall the mesh included in the package?
I presume it's for the capsule, but i cannot figure out how to open the capsule and install the mesh ....or i'm in the wrong direction ?
Mesh covers the air-slots of the bodytube, right underneath where you screw on the capsule. They're not installed in case you want to paint the tube first.
The capsule is fully ready. Once your mic is finished, just screw them on and you're good to go.
jordan s said:
Where can I find a replacement mesh? I am missing one.
Hey Jordan, I can send you a replacement sheet – you can cut a few new ones out. Shipping would be a few bucks.
Otherwise you can find them in specialised hardware stores: anything around 50 mesh should be similar (stainless steel).
Banzai said:
Hey Ikipod,
The screws were included in the spring/mesh bag. If you have a couple of units, it will be in one of the bags.
Size is M2.
Great!!
Thanks a million!
Moshe
Thank you, jordan s
I see.
Still, it seems difficult to try any of these methods.
I need to experiment.
Thank you anyways.
jordan s said:
I posted 3 different methods borrowed from the U87 project above.
guismarquesrj said:
Hey everyone
I've just built my first one and no luck yet... It's "windy", like with lots of constant artifacts and VERY LOW gain... Something is very wrong...
Double checked all the solder joints and looks fine...
BUT, first I figured out that I placed the C4 inverted (duhhhhh), tested it with 48V on, etc... and of course it won't work properly...
Then I corrected it and nothing changed...
Any ideas?! Maybe I screwed the FET?
Thanks!!!
Any ideas?! Heeeeeelp!
Just built the second one and it's exactly the same!!! DAMN!!!
Is there something really dumb that I'm missing?!
To measure the voltages, I plug the XLR without the capsule screwed and then measure the test points as in the schematic?
If you're like me, you bought bad fets from China/ebay.
Feeling REALLY dumb... I missed connecting the white/red and white/brown xformer wires together... :/
damn...
Now the mics are working perfectly... VERY nice sound!
I'm in for another pair! haha
THANKS!
Sorry folks, I've been way off-grid doing trying to clear a backlog of recording/mixing work.
For those who have had a go with something other than the 2N3819 and it's not playing the game, I'd say it's worth double checking the pins on the FET.
I got caught with that a while back using a J211. Good FET, but totally user error! It was super quiet when powered up and I buggered around for ages trying to work out what the hell was going on. Turns out the pins are different on that FET and I hadn't picked up on it when I looked at the data sheet. It could be the same with some of the other things (maybe Chinese rip-offs) that people are using so it's worth a check, I reckon.
G
..the last two batches of 2N3819 I bought turned out fake, just some rebranded generic NPN transistor..
They were branded, with laser marking:
(Fairchild-Logo-F)
BJ12
2N3819
I just ordered some 2n3819s from china.
I bought 30 of them to check the HFE and use the highest ones.
Is that enough testing?
If they are fake, will they work?
I would highly recommend NOT buying the Chinese FET's as gyraf has pointed out, they are rebranded BJT's and will not work. The ones I got from Small Bear were very cheap and good quality. Why deal with fakes?
To be fair, even though the prices are good for the Chinese ones it's not much use if it doesn't work in the circuit. You're better off getting them from a better source,  or try some equivalents. Just double check those pins... Like I said above, it's a simple mistake, but it got me.    ::)
No Hfe on JFETS, has infinite current gain
I simply test with a transistor tester like https://www.banggood.com/DIY-Meter-Tester-Kit-For-Capacitance-ESR-Inductance-Resistor-NPN-PNP-p-929603.html - it clearly identifies your transistor type and idss etc for jfets
Jakob E.
Simple questions about BIASing the mics when feeding 1Khz at the gate:
Is it meant to be measured with the capsule disconnected and feeding 48V trough the XLR?! Or simply with everything disconnected?!
Can I feed the 1khz trought the spring connector? Doesn't it make sense?!
Just finished and calibrated my pair. Amazing sounding mics! Thank you for putting this together.  :)
