KM84 revisited
jp8
GDIY Supporter
Netherlands
If you have been following this and this thread of @joulupukki , you know that I have made two SMT variants of the KM84 circuit with several improvements compared to the classic KM84 circuit. For convenience, I have called these circuits KM84+ and KM84++. They are described in detail on my website, which I have now launched. You will find the links below. The KM84+/KM84+ article texts are not completely finished yet, but I plan to finish them during the Christmas holidays. I hope you'll enjoy reading the articles on my website and find them useful!
I will make KM84+/++ PCBs available for the Takstar CM-60 and CM-63 and Alctron T-02A on PCBWay, but at the moment of writing, I have only finished the building instructions for the KM84+, suitable for the CM-60 microphone.
Links to KM84 and KM84+/++ articles on my website:
KM84 circuit description: https://modimications.com/km84-style-charge-amplifier-circuit/
KM84+ and KM84++ description: https://modimications.com/km84-and-km84-head-amp-circuits/
Takstar CM-60 and CM-63 description and mods: https://modimications.com/takstar-cm-60-and-cm-63/
Available PCBs (at the moment only one, but you get an idea of what I'm working on: https://modimications.com/all-orderable-pcbs/
When more KM84+/++ PCB variants become available, I'll keep you informed via this thread.
Note: unfortunately, my website does not display correctly on mobile devices. I'll have to work on that.😕
Happy reading and Merry Xmas to all!
As far as I see, the schematic of the Takstar CM-60 is not correct.
In the DC converter C4 should be connected to the junction of L1 and C5, not to the emitter of Q1.
Also I have a feeling that C6 (usually 22 or 27 pF) is connected between collector and emitter of Q1.
In general C5 is 6.8 or 7 pF. The position of R9 looks 'strange'. (Collector Q1 not decoupled.)
Thank you Ruud for your valuable comments! I assume you were referring to the schematics here on my website. I checked the circuit diagram, and you were partially right.
  • C4 should indeed connect to the C5-L1 junction.
  • C6 is connected as depicted! You'd indeed expect it to be wired as depicted in the CM-63 schematic, i.e. between Collector and Emitter, but it isn't. I removed the capacitor from the PCBA and measured its value using my Smart Tweezers. It measured 2.7 pF.
  • I also measured the value of C5. It's value is 22pF.
  • While checking the circuit, I also noticed another error: trimmer P2, which is actually not placed, does not shunt R8 but R9 instead. I assume R9 was added to reduce the output voltage, and with P2, the capsule bias voltage can be adjusted. There is NO decoupling capacitor on the R9/Q1/R10/D2/C3 node!
I have revised the schematic accordingly and published it on my website.
If anyone used the KM84++/CM-63 Centroid file, kindly note that the initial version I uploaded with the design on PCBWay used the wrong reference point. I have uploaded a new one using the right reference (bottom-left corner of the PCB, looking from the Top side).
