> pin 5 of the 6AQ5a. I have 171 volts as opposed to 100 volts
It is a pentode. Plate voltage isn't controlled except indirectly with G1 and G2 voltage. It would be normal to see +/-30% variation.
In this type circuit, plate voltage should probably be "about half" of B+ voltage. Either 100V or 171V might be fine.
Before you go further:
Trippple-check all the resistors around the 6AQ5. You can go nuts trying to find the complicated problem, when it was really just a red stripe where it should have been a brown stripe.
Let the thing cook (on a fire-proof table!) for about 24 hours. Tubes can drift in storage and heal themselves while running. Gas is possible, though your symptoms don't look like gas. It could be leakage in the capacitors, which should heal (or smoke!) overnight.
Then:
Re-check the cathode voltage and resistor value. This should be very close to nominal.
If the cathode voltage is low and the plate voltage is high, the tube is not passing as much current as the chart says. In a pentode, the best step is to increase the G2 (Screen grid) voltage a little. Screen grids fed from a large dropping resistor, as the LA2 does, are not real precise. The plan I have here shows a 220K resistor from +275 to 6AQ5 pin 6. We want more plate current. We want higher screen voltage. So try changing from 220K to maybe 150K.
