La2a rackmount ears
Jazz
USA - Portland Oregon
Anyone know where to get some rackmount ears similar to the original?
I've been looking all over. I'm also trying to find a VU meter fairly close to the factory version
TIA
:thumb:
NO and no.
Beede made the original meter. For a while Scenaria was using them, until they decided to wind down that production line. Now they will onlt produce meters of that type with a minimum order of 1,000 pieces, at $US125 each. In order to buy one, you'd have to front a $125,000 group buy. Of course this is possible for volume manufacturers like UA, but not for anybody else.
The "rack ears" were part of the case. You can look and find 3U rack ears if you're lucky, but they would have to work with your box width... good luck with that one.
So -in short- no and no.
Keith
Hey Keith,
The rack ears actually bolt onto the chassis, but this probably doesn't help anyways...
Really? -I posted from memory, but with the utter conviction of being correct...
Let me look...
Dammit...
You're right!
-Okay... so my memory completely misled me there. -However, the fact remains that you need the width to match your project case, which may well be a variable number.
Keith
Maybe these at IehBäh?
http://cgi.ebay.de/UREI-LA4-RACK-KIT_W0QQitemZ150059832172QQihZ005QQcategoryZ21774QQrdZ1QQcmdZViewItem
good luck
I found in my stock some Hewlett-Packard Rack Adapter Kits
they are 3 1/2" high. Part Number 5061-0072
Anyone interested PM me... Have 3 in stock... NOS
Steve @ Apex Jr..
when i was racking my 1/2" and 1/4" tape decks, i just bought a 2meter length of 2mm thick 50mm x 50mm L extrusion steel and chopped and drilled that sucker myself.
hey, it looks commando, but that's fine by me!
chris
