http://www.groupdiy.com/index.php?topic=6620&start=30
[quote author="emrr"][quote author="Rob Flinn"]Donny Sparks
With regards to my post:
and Rob,
"Just a small point but if you have these mic amps set for +24dBm operation the harmonic generation is greater by 0.25% than if you have them set for +18dBm."
is that desireable harmonic generation as in even harmonics?
Probably the best thing to do is try it both & see if you notice a difference. Then you have the option of hardwiring one way or being able to select the harmonic generation with a switch.[/quote]
I'd think the distortion would be primarily 3rd harmonic, being a balanced circuit.
I think this power/distortion issue needs to be looked at another way. WITH 6 DB MORE LEVEL GOING THROUGH THE UNIT, you get another 1/4% distortion. This is true of most any gear at some point approaching the maximum headroom. I bet it's at least the same (if not lower) distortion when set for high power with identical levels (say, +16 dBm) passing. Is it the transformers approaching saturation at the higher power level? Is it the transistors? Is it both? Anyone really know?
Another thing; this is a fixed gain preamp. When you go high power for more output capability, the maximum input point also moves. So, there is a magic point in the headroom shift where the lower power setting will crap out and have more distortion than the higher power setting. If the specs are to be trusted, then -27dBm is maximum input for the low power setting, and -21dBm is max for the high power setting, so -24dBm would be a problem for the lower power setting and yield more distortion than the higher power setting. If you extend that thought to 20 db input pads, you still end up in a zone where the output of many modern condensers could cause problems with the low setting. Hell, with the high settting too. At any rate, I'm not convinced there's a great reason to run at the lower power setting, at least not with any type of loud input signals and hot mics. If you're always putting a 77DX into it then it could be another story.
There may be some noise issues with the power shift that I can't address from experience yet. I believe Soundguy had some commentary about greater noise in the AM-17 with the higher power strapping, but that is actually a shift from 1W (high line level) to 8W power amp level, with power transistors as outputs. They may behave differently.
Put in a power shift switch if you really want to nerd out......[/quote]
