At the moment i'm testing a Lawo W995-1 for mastering applications. Il love the eq tone and curves but i want to be sure i can solve some problems before to buy it.
The unit is noisy at high frequencies and one channel way more than the other. This channel is less noisy when :
- I push -2db 1.5Khz the noise disappears ( become as the other channel ), i bypass the channel, unbypass the channel and the noise reappears , with same settings...
- The PSU is a cheap Smps, i think a linear power supplie can reduce HF noise, but why a channel more than the other ?
- I would like to mod the gain, not sure what gain range i want at the moment but divide all the gain range by 2 it's maybe the simplest way ?
- The amphenol relays are not working correctly, i have to change them, but if i "bypass" the bypass section, relays, opamp... maybe can i reduce moise ?
- What the beneficial to change the single power supplie to symetrical psu ?
The schematic is for the Lawo 995-3 but i think they are identical.
