[quote author="Infernal_Death"]Sorry if it's already said but you should avoid 90 degree turn traces. I am not experienced in drawing layouts but i remember to read that you should avoid them. Maybe some of the more experienced here can tell you why.
[/quote]
Etchant tends to go underneath the resist a bit, creating a thinning of the trace as you go towards the substrate. In an acute corner, this is exaggerated, and can cause a severe thinning of the trace. They call that 'acid trapping' but the etchant really is usually ammonium chloride for commercial production and ammonium persulphate or ferric chloride for DIY work. In addition, right angles are bad for both RF immunity and radiation.
Commercial PC boards have no problem with 0.006" trace widths and spaces these days, but if I'm doing a home-etch, I like to use a minimum of 0.012" trace but usually 0.018" or 0.020", but I use litho film to make artwork so I think I can go pretty thin on trace widths and get away with it.
I also like to copper-fill because that really makes the etchant last longer, and seems to make the etch go smoother, at least I find that it does.
-Dale
