LCR meter
you might find a used B&K  in that range I used one when I was with honeywell / novar  and it was sweet I think it was a model 800 but don't hold me to that its been a few yrs
Bill
I have this one too [Amprobe 37XR-A]:
http://www.amprobe.com/cgi-bin/pdc/viewprod.cgi?pid=2146&tid=main_e&type=elec
Less powerful than the Peak LCR, but more useful for continuous measurements, i.e. on variable inductors.
i just bought the atlas lcr-40 a few weeks ago cost me 98 euro's incl. shipping and 2 extra batteries to Holland. really nice simple to use meter, the only meter i could find in the minus 300 range that measured L and C at different freuencies. I recommend getting some of the other probe options because the supplied leads are kinda short. Not the most precise meter but a bargain overall. 2 thumbs up!
greetings,
thomas
AIM LCR Databridge 451
Laboratory model high precision, can be found under $100
Wow.
Anyone using the M3 LCR?
I do a lot of custom guitar and bass pickup winding and I use an Extech 380193.  It's worked flawlessly for my needs.  They're about $200.00.
Don
What about using LIMP wich is a part of ARTA software?
http://www.fesb.hr/~mateljan/arta/support.htm
According to app note2 :
"The program Limp can be used to measure value of resistors, capacitors and inductors, simply by
calculating resistive, inductive or capacitive parts of the measured impedance"
Axel
I've seen the specs.. its amazing indeed for the price.
They've also a semiconductor analyzer which does also voltage threshold, saturation current and RDSON measurements for JFETs..  :)
Agilent U1731A (200 euros) or Agilent U1732A (240 euros).
http://www.home.agilent.com/agilent/product.jspx?cc=US&lc=eng&ckey=1591964&nid=-34196.881632.00&id=1591964
http://www.home.agilent.com/agilent/product.jspx?cc=US&lc=eng&ckey=1592236&nid=-34196.881634.00&id=1592236
Too bad they says no shipping outside USA and Canada..
And here, of course, an Indian clone.
[edit] the Agilent U1731[2]A, Limp, Atlas lcr-40, B&K 878A-879, are light-years away from the capabilities of the M3..
..that said, the U1732A is not bad.[/edit]
owel said:
Any recommendations?
Under $300 price range.
Pl check this LCR Meter @ 200 Euros + shipping with 100 Hz to 25 kHz test frequencies, Duel test voltages, Bias , Transformer test facility. Coil turns tester. Check at [edited]
A B Bhagwat
-Such items need to be listed in the WHITE market, after first meeting the requirements of posting there.
You would of course be most welcome to post there, and your item looks very interesting, but A couple of forum users have indicated that they're uncomfortable with any users getting 'free advertising' here while others do not.
With that in mind, I've edited your post.
Thanks for your understanding,
Keith
Yes the guy is a bit here on the spamming side,
but I must say, just received today his LCR meter, its pretty darn good, true lab-grade unit.
